BrokenDome
Nov 09, 2020Initiate
Problems with zoom
Hello. I having been having an issue with my router since I purchased it. I don't believe that it's my router, I believe that my settings are not properly done, but I am not sure how to fix it...
- Nov 10, 2020Please try disabling DumaOS Classified Games and see if that helps. If it doesn't then toggle SIP ALG in WAN Settings and see if that fixes it.
Netduma-Fraser
Nov 10, 2020NetDuma Partner
- BrokenDomeNov 12, 2020Initiate
Thank you very much for the quick reply. After I turned off DumaOS Classified Games like you said, it seems to be running much better. Not sure why this feature would make a difference but I definitely appreciate your help. Thank you!!
- Netduma-FraserNov 12, 2020NetDuma PartnerIt was likely classifying something else as high priority traffic and that was putting zoom in a network queue which caused the issues. When not using zoom you can re-enable for your games.
