BrokenDome
Nov 09, 2020Initiate
Problems with zoom
Hello. I having been having an issue with my router since I purchased it. I don't believe that it's my router, I believe that my settings are not properly done, but I am not sure how to fix it...
- Nov 10, 2020Please try disabling DumaOS Classified Games and see if that helps. If it doesn't then toggle SIP ALG in WAN Settings and see if that fixes it.
BrokenDome
Nov 12, 2020Initiate
Thank you very much for the quick reply. After I turned off DumaOS Classified Games like you said, it seems to be running much better. Not sure why this feature would make a difference but I definitely appreciate your help. Thank you!!
Netduma-Fraser
Nov 12, 2020NetDuma Partner
It was likely classifying something else as high priority traffic and that was putting zoom in a network queue which caused the issues. When not using zoom you can re-enable for your games.
