JonSnowKnowsNad
Feb 11, 2020Apprentice
PS4 Downloading only at a 50 mbps
im monitoring my ps4 while its doing the modern warfare season 2 update which is around a 50 GB download and the network monitor only shows it downloading at 50 mbps sometimes it goes up and sometime...
Feb 11, 2020Guru - Experienced User
JonSnowKnowsNad wrote:im monitoring my ps4 while its doing the modern warfare season 2 update which is around a 50 GB download and the network monitor only shows it downloading at 50 mbps sometimes it goes up and sometimes it goes down. i even allocated like 130 mbps to my ps4 on the QoS. I usually get 150 mbps on download on speed test. isnt it supposed to download faster.
The other issue is the download is set by whichever server the modern warfare session is on. It might only have the capacity at that time for 50mbps. Just because you set 130mbps, doesn't mean its available from MW.
- JonSnowKnowsNadFeb 11, 2020Apprentice
what should i do then sensei?
- plemansFeb 11, 2020Guru - Experienced UserNot a lot you can do. If a speed test is giving you full speed then your modem, router, setup is working as it should. It's the modern warfare or whatever game your playing at the time limiting the speed.
do you have any sources? if im downloading modern warfare update and its not downloading at the speed my isp/speed test results show your saying that it's not because of my router/modem/wiring?
