JonSnowKnowsNad
Feb 11, 2020Apprentice
PS4 Downloading only at a 50 mbps
im monitoring my ps4 while its doing the modern warfare season 2 update which is around a 50 GB download and the network monitor only shows it downloading at 50 mbps sometimes it goes up and sometime...
Netduma-Fraser
Feb 11, 2020NetDuma Partner
Speedtest and ISPs measure speed in megabits per second, your downloads are done in megabytes per second so 150 megabits equates to roughly 18.75 megabytes per second. That is the reason why it seems as though there is a discrepancy.
JonSnowKnowsNad
fraser, im confused so are you saying the network monitor is telling me how much bandwidth each devices are using in megabytes per second? because its not when i do a speed test on my pc. the network monitor will show that my pc is using 150 download and 15 upload. which is near identical to what my isp/speed test results are.
