JonSnowKnowsNad
Feb 11, 2020Apprentice
PS4 Downloading only at a 50 mbps
im monitoring my ps4 while its doing the modern warfare season 2 update which is around a 50 GB download and the network monitor only shows it downloading at 50 mbps sometimes it goes up and sometime...
JonSnowKnowsNad
what should i do then sensei?
Feb 11, 2020Guru - Experienced User
Not a lot you can do. If a speed test is giving you full speed then your modem, router, setup is working as it should. It's the modern warfare or whatever game your playing at the time limiting the speed.
- JonSnowKnowsNadFeb 11, 2020Apprentice
do you have any sources? if im downloading modern warfare update and its not downloading at the speed my isp/speed test results show your saying that it's not because of my router/modem/wiring?
- plemansFeb 12, 2020Guru - Experienced User
JonSnowKnowsNad wrote:do you have any sources? if im downloading modern warfare update and its not downloading at the speed my isp/speed test results show your saying that it's not because of my router/modem/wiring?
Correct.
If you speedtest on your pc/laptop, its usually running off a server designed to saturate a internet connection. For your modern warfare setup, its going PC------>router---->modem------>ISP (and several other steps)-------Modem/gateway (MW side)---------> modern warefare server. If MW maxed out everyone's connection, they'd have to pay for a rediculous connection to the ISP. so they limit their max speed a bit. It's going to be a bit variable as users are connected to the MW server and using bandwidth.
Just because you have 150mbps connection doesn't mean the modern warfare or other gaming servers are going to saturate that connection. I have a gigabit connection and I rarely see anywhere need gigabit speeds unless I'm speedtesting.
