JonSnowKnowsNad
Feb 11, 2020Apprentice
PS4 Downloading only at a 50 mbps
im monitoring my ps4 while its doing the modern warfare season 2 update which is around a 50 GB download and the network monitor only shows it downloading at 50 mbps sometimes it goes up and sometime...
JonSnowKnowsNad
do you have any sources? if im downloading modern warfare update and its not downloading at the speed my isp/speed test results show your saying that it's not because of my router/modem/wiring?
Feb 12, 2020Guru - Experienced User
JonSnowKnowsNad wrote:do you have any sources? if im downloading modern warfare update and its not downloading at the speed my isp/speed test results show your saying that it's not because of my router/modem/wiring?
Correct.
If you speedtest on your pc/laptop, its usually running off a server designed to saturate a internet connection. For your modern warfare setup, its going PC------>router---->modem------>ISP (and several other steps)-------Modem/gateway (MW side)---------> modern warefare server. If MW maxed out everyone's connection, they'd have to pay for a rediculous connection to the ISP. so they limit their max speed a bit. It's going to be a bit variable as users are connected to the MW server and using bandwidth.
Just because you have 150mbps connection doesn't mean the modern warfare or other gaming servers are going to saturate that connection. I have a gigabit connection and I rarely see anywhere need gigabit speeds unless I'm speedtesting.
- Netduma-FraserFeb 12, 2020NetDuma PartnerApologies, I misread that it was saying 50 on the console. The Network Monitor is showing in Megabits, it depends what you're looking at on the monitor as well - the Snapshot shows more of an average so it might be averaging at 50. The Overview shows you the fluctuations in the speed (a download will never just constantly stay at the same speed) so it may be downloading as fast as it can if there are wide variations.
- NewfiedroolFeb 12, 2020Virtuoso
Turn your QoS off. Every time I was downloading on the PS4 with no games running I had to turn off QoS to allow it to max out. Make sure bufferbloat is not stuck on, it's a bit temperamental.
- JonSnowKnowsNadFeb 12, 2020Apprentice
its actually fine. i think what sensei said is most likely correct as i was downloading call of duty titles like Black ops 3 and Ghosts yesterday and it was downloading really fast, but updating Modern warfare 2019 was going hella slower than usual . and the network monitor showed speeds above 150+ Mbps when i was downloading black ops 3 and ghosts which i get on speed test results. i dont run bufferbloat because i dont want my speeds being capped.
