ElPresidente
Mar 18, 2020Follower
PS4 Party Chat
For about a week I haven't been able to get PS4 party chat to work properly, I have had my router for over a year and have not changed any setting recently although I got an email about a new update ...
Cujoma
Apr 13, 2020Guide
Put it in spectating mode. It will work instantly. There is an issue with party chat and the ps4. You arent alone. i have the issue. Lots of people do. You can try pinging each friend and allowing them, but if their ip changes youll have to do it all over again. Easiest solution is to put yourself in spectating mode. It will work right away. Hopefully netgear or duma come out with a fix for this problem. There has to be ps4 servers that should be whitelisted to allow this to work
Netduma-Fraser
Apr 14, 2020NetDuma Partner
It's not necessarily that issue but we'll be doing another cloud update asap so if it is then it'll be fixed.
- CujomaApr 14, 2020GuideSounds great. Keep us posted as to when there will be an update or fix please. Thanks in advance!
