Asiantoybox
Feb 22, 2020Tutor
PS4 Port Fowarding
How do you add foward ports with two different set of numbers? I have a ps4 and the ports that I want to add to my XR500 are TCP: 80, 443, 3478, 3479, 3480 and UDP: 3478, 3479. I hav trying to put th...
Asiantoybox
Feb 22, 2020Tutor
Also, when I was trying to add the ports, it says ''internal port range must have the same fequence of ports as in the external port range''.
Netduma-Fraser
Feb 23, 2020NetDuma Partner
That isn't NAT related, you need to add your friends to your Geo-Filter allow list. You can see how to do this at the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
Did you untick that option I mentioned?
- AsiantoyboxFeb 23, 2020Tutor
yes I have unticked that option you mentioned. As for adding players in the geo filter settings, do I have to add the player and the server in order to join that player playstation party chat?
- Netduma-FraserFeb 23, 2020NetDuma PartnerWith that option un ticked I'm able to use different ports for internal and external, does it still not allow you to do that? No you just need to add your friend for party chat. The game server will be allowed through your normal Geo-Filter radius.
- AsiantoyboxFeb 24, 2020TutorIt’s still saying the same thing needs to be the same port numbers for the internal and the external
