Wyzfar's avatar
Wyzfar
PS4 Ports
Hello thank you for your help so basically i am wonderin if i DMZ My PS4 Pro Should i also port forward the ps4 ports ?
1 Reply
  • If you use the DMZ then it basically forwards all the ports to that device so completely unnecessary to use port forwarding as well.
