jebrown1979
Jun 22, 2019Guide
ps4 randomly disconnects on xr500
the ethernet disconnected twice yesterday causing my ps4 to lose online status untill i rebooted. also my samsubg galaxy tab 3 can only use 20 mins of wifi before it disconnects and have to be reconn...
Jun 23, 2019Guru - Experienced User
Ensure your using good quality LAN cables. CAT6 is recommended.
Set a IP address reservation for the PS4 and any other devices connected ON the router.
Possible you have BB set to low, try 80 or 90% and see if this still continues to happen.
jebrown1979
Jun 24, 2019Guide
the firmware is the latest V2.3.2.40 A7legit. its my isp white ONT box not a modem that my router connects to i send you a pic if you want.
i tried BB 85% it worked for a while then 2 disconnects but gameplay wise it was alot better. going to try BB at 90%
i have an AFX gaming cat6 cable from my white ONT box to my router and the same cable from my router to my ps4 they cost £20 each so i hope they are good cables lol.
- jebrown1979Jun 24, 2019Guide
oh and when it does disconnect it sometimes comes back as 100MB connection so i have to unplug then plug back in to get the white light on my router. but the strange thing is my pc when powered down i mean totally off shut down still shows a red light on the router but when ps4 is shut down there is no light which leads me to believe there is something wrong somewhere
- CeeDaRulaJun 24, 2019Aspirant
Funny how this issue is happening with XBox as well.
are we to do a total factory reset and set up everything again its just frustrating how some people dont have problems but others do
- FURRYe38Jun 24, 2019Guru - Experienced User
Is there any kind of power saving or instant ON silimar features enabled on PS4. If the connection is being reported as 100Mb after a disonnect, symptoms of possible bad cable, bad console or bad router.
I would downgrade to v32, factory reset and setup from scratch and see if that changes anything.
jebrown1979 wrote:oh and when it does disconnect it sometimes comes back as 100MB connection so i have to unplug then plug back in to get the white light on my router. but the strange thing is my pc when powered down i mean totally off shut down still shows a red light on the router but when ps4 is shut down there is no light which leads me to believe there is something wrong somewhere
the cables are only a 2 nonths old same time as i bought the router will try installing the other firmware and setting it all back up is there a link for the firmware thans
