akmuskeg
Dec 28, 2022Aspirant
PS5 and Xbox Series X fighting over ports and PS5 is winning
I am hoping someone can help by indicating if one of the Nighthawk routers will take care of this problem. It must keep the consoles completely separate to keep the PS5 from taking over. We have n...
Dec 28, 2022Guru - Experienced User
New kind of expereince. Haven't see this posted about before.
Seems like this would be a Sony/MS issue rather than a router issue.
- akmuskegDec 29, 2022Aspirant
Yes, the PS5 is the problem but the research we have done suggests that Netgear Nighthawk routers may be the answer, the R7000 has been mentioned specifically but we are wondering if any other models have had the same success. Thank you for your response.
- FURRYe38Dec 29, 2022Guru - Experienced User
What happens if you turn on the xbox first?
Would need to know what the R7000 configuration is that was mentioned to tell if other NH router could do the same.
Possible NAT Filter option could be helpful here...All NG routers have this feature.
