BSlaman's avatar
BSlaman
PS5 Chat random disconnects on XR500 V2.3.2.114 and QOS
Hello, I'm recently facing PS5 disconnects with the XR500 router since some time. I tried a lot but the only thing that works is turning of Qos, which drastically impacts the rest of the network. ...
  • Netduma-Liam's avatar
    Netduma-Liam
    May 10, 2021
    With Geo-filter enabled, keep an eye on the Geo-filter map when joining a PS5 party. You will likely see a server or two pop-up as blocked and you'll need to manually allow these. You may find you have to do this a couple of times but after that you should be good to go.
