BSlaman
May 09, 2021Aspirant
PS5 Chat random disconnects on XR500 V2.3.2.114 and QOS
Hello, I'm recently facing PS5 disconnects with the XR500 router since some time. I tried a lot but the only thing that works is turning of Qos, which drastically impacts the rest of the network. ...
- May 10, 2021
With Geo-filter enabled, keep an eye on the Geo-filter map when joining a PS5 party. You will likely see a server or two pop-up as blocked and you'll need to manually allow these. You may find you have to do this a couple of times but after that you should be good to go.
BSlaman
May 10, 2021Aspirant
To the looks of it, I turned off Geo Filtering, and it worked yesterday. My kid also said she had no trouble. I'll be updating
Netduma-Liam
May 10, 2021NetDuma Partner
