Evanfly
Oct 26, 2022Guide
PS5 Playstation plus Streaming PS3 Games
Hello I have a PS5 connected to a XR1000 by Ethernet & recently I have upgraded my PS Plus subscription to also include streaming of PS3 games but I get the following error: "Can't connect to the se...
michaelkenward
Oct 26, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Evanfly
Oct 26, 2022Guide
Thank you apologises
- michaelkenwardOct 26, 2022Guru - Experienced User
No need. This place is a mess and it is easy to get lost.
I didn't want you sitting around waiting for someone to find your message.
- Netduma-LiamOct 26, 2022NetDuma Partner
It's odd that you only seem to have this issue specifically with streaming games.
Can you go to the XR1000 interface by opening a web browser and going to routerlogin.net.
Here, login and go to Settings -> Setup -> WAN Setup and check that UPnP is enabled and then set the Filtering type to Open.
After that, see if you're able to stream games.
- EvanflyOct 26, 2022Guide
Thanks for the reply I'm pretty sure they are both set as you suggested I'm currently out at present but will double check the setting when I'm home & report back.
- EvanflyOct 26, 2022GuideJust rechecked & both settings are already set as requested,I've just retried to stream a game with the same results
- FURRYe38Oct 26, 2022Guru - Experienced User
I would power OFF the ONT, router and game consoles. If there is a way to flush the networking caches on the consoles, this would be good as well. Xbox you hold the power button until it shuts off. I don't know if PS consoles do same.
Then bring the ONT back ON then the router. Once the two are online, turn on the PS console, one and check gaming on the one console. Then try the 2nd console.
