Evanfly
Oct 26, 2022Guide
PS5 Playstation plus Streaming PS3 Games
Hello I have a PS5 connected to a XR1000 by Ethernet & recently I have upgraded my PS Plus subscription to also include streaming of PS3 games but I get the following error: "Can't connect to the se...
Evanfly
Oct 26, 2022Guide
Thank you apologises
Netduma-Liam
Oct 26, 2022NetDuma Partner
It's odd that you only seem to have this issue specifically with streaming games.
Can you go to the XR1000 interface by opening a web browser and going to routerlogin.net.
Here, login and go to Settings -> Setup -> WAN Setup and check that UPnP is enabled and then set the Filtering type to Open.
After that, see if you're able to stream games.
- EvanflyOct 26, 2022Guide
Thanks for the reply I'm pretty sure they are both set as you suggested I'm currently out at present but will double check the setting when I'm home & report back.
- EvanflyOct 26, 2022GuideJust rechecked & both settings are already set as requested,I've just retried to stream a game with the same results
- FURRYe38Oct 26, 2022Guru - Experienced User
I would power OFF the ONT, router and game consoles. If there is a way to flush the networking caches on the consoles, this would be good as well. Xbox you hold the power button until it shuts off. I don't know if PS consoles do same.
Then bring the ONT back ON then the router. Once the two are online, turn on the PS console, one and check gaming on the one console. Then try the 2nd console.
- EvanflyOct 26, 2022GuideJust tried that same result
