Evanfly
Oct 26, 2022Guide
PS5 Playstation plus Streaming PS3 Games
Hello I have a PS5 connected to a XR1000 by Ethernet & recently I have upgraded my PS Plus subscription to also include streaming of PS3 games but I get the following error: "Can't connect to the se...
Netduma-Liam
Oct 26, 2022NetDuma Partner
It's odd that you only seem to have this issue specifically with streaming games.
Can you go to the XR1000 interface by opening a web browser and going to routerlogin.net.
Here, login and go to Settings -> Setup -> WAN Setup and check that UPnP is enabled and then set the Filtering type to Open.
After that, see if you're able to stream games.
Evanfly
Oct 26, 2022Guide
Thanks for the reply I'm pretty sure they are both set as you suggested I'm currently out at present but will double check the setting when I'm home & report back.
