Evanfly
Oct 26, 2022Guide
PS5 Playstation plus Streaming PS3 Games
Hello I have a PS5 connected to a XR1000 by Ethernet & recently I have upgraded my PS Plus subscription to also include streaming of PS3 games but I get the following error: "Can't connect to the se...
Oct 26, 2022Guru - Experienced User
- EvanflyOct 26, 2022Guide
The router is on firmware 1.0.0.64 not sure of the details of the make/model of the ONT as I'm currently out if it's any help I'm with BT again will check those details once home. thanks
- FURRYe38Oct 26, 2022Guru - Experienced User
- michaelkenwardOct 26, 2022Guru - Experienced User
You are in safe hands with Netduma-Liam. (Next thing you know someone will ask about your cables.) They know their DumaOS.
Depending on your service, being with BT could mean that you have one of those nasty HomeHubs. These are modems/routers that make it hard to play nicely with third party routers.
What is Double NAT? | Answer | NETGEAR Support
More recently, BT has shipped set-top BT TV Box Pro things that you can use alongside a grown up modem.
If it really is an ONT, you should be OK, but it might be worth dropping by the BT community if problems persist.
Welcome to BT’s official support community.
If this just started happening when you added to your PS Plus subscription, and all worked well before then, that might also be a good place to seek help.
It is easy to assume that the router us the source of all woes, but with so many interacting things the real culprit could be anywhere.
It's plugged directly into the ONT I've got BT full fibre
