Evanfly
Oct 26, 2022Guide
PS5 Playstation plus Streaming PS3 Games
Hello I have a PS5 connected to a XR1000 by Ethernet & recently I have upgraded my PS Plus subscription to also include streaming of PS3 games but I get the following error: "Can't connect to the se...
Yousif1
Oct 26, 2022Aspirant
Can you go to the XR1000 interface by opening a web browser and going to routerlogin.net.
Here, login and go to Settings -> Setup -> WAN Setup and check that UPnP is enabled and then set the Filtering type to Open.
After that, see if you're able to stream games.
Evanfly
Oct 27, 2022Guide
Hi Yousif1 yes I've done that It appears to be related to the Geo filter that's causing the issue. Thanks
- Netduma-LiamOct 27, 2022NetDuma Partner
Can you zoom all the way out on the Geo-filter map and then when you try to play a game, watch for a 'blocked' icon to appear. When this occurs, please click the icon and manually allow the connection in the panel that appears below the map.
After that, you should be able to play. Of course the alternative would be to temporarily disable filtering mode when you want to play these games.
- EvanflyOct 27, 2022Guide
Morning Liam I will try your suggestion just to see if it works I don't know how the streaming with ps3 games works as the two that I tried the icon appeared in the US (not sure if they are all based there) I'm in the UK & you would think there would be something over here.
Can you just clarify this for me even though I turned off filtering mode when I tried Call of Duty the icons appeared within my radius approx. 1000 miles am I right in thinking that if nothing appeared within that range it would then search outside that but with filtering enabled it will only search within the radius.
I've also got the following settings configured are these ok:
UPNP>Enabled
Filtering Mode>Open
Ref congestion I've set the sliders to 70% & Auto enabled
QOS I've set gaming upload & download to 20
Is there anything else I can tweak to optimize online gaming
I'm connected via ethernet & on full fibre 900 which gives me approx 1000 download 110 upload
Thanks
It's often the case that they're just authentication servers that the game needs to communicate with in order for you to play. Most often you won't be playing on that server, it's just for you to authenticate.
On Geo-filter, that's right, with filtering mode disabled you can still see the connections but Geo-filter will not affect them. With Filtering mode enabled, Geo-filter will ensure you are not getting connected to any servers outside of your filter radius.
You're config sounds good, nice job. One last thing I'd suggest trying:
Disable both the default rules in QoS -> Traffic Prio and instead add a new one, select your PS5 as the device and select Games Console as the service.
After that, give it a go and let us know how it feels!
