dark_tribute381
Sep 02, 2020Aspirant
PSN/WiZ LAN Issues
I have recently upgrade from ADSL2 to NBN in Australia, Since the upgrade which moved me to a VLAN/Bridge setup as "VLAN ID 2", "Priority 0" which then connects the WAN Socket and that goes to a netc...
Netduma-Fraser
Sep 03, 2020NetDuma Partner
In WAN Settings changed NAT to Open instead of Secure, does that resolve the issue?
dark_tribute381
Sep 03, 2020Aspirant
I had previously changed this to open, there was no improvements on there network stability. It seems all devices that authenticate over the internet that are connecting locally to one another are affected.
TVs, Soundbars, and Printers are all functioning as normal only Google Home, Google Nest, WiZ Smart Lights, PS4 & PS4 Pro are affected
- Netduma-FraserSep 04, 2020NetDuma PartnerCould you double check if you have the old router handling VLAN and the XR behind it whether you get the same issues? Prior to this though disable QoS completely from the Anti-Bufferbloat option 3 line option menu and see if that helps.
- dark_tribute381Sep 08, 2020Aspirant
I disabled QoS, No Improvement.
What do you mean have the N600 handle VLAN and the XR behind it? I am assuming you mean set the XR up in AP Mode?
- Netduma-FraserSep 09, 2020NetDuma PartnerRemove the VLAN options from the XR. Put the VLAN options in the N600 instead, then just connect the XR500 to the N600 no AP mode and see if it works correctly.
