WacoJohn
May 02, 2020Luminary
Purevpn on XR500 works but throughput slowed.
VPN enabled ... 15mbs down. Disabled .... 200mbs down. Any suggestions? Thank you in advance. firmware 2.3.2.56
- May 02, 2020Do Not VPN these services with no services added means the entire device is behind the VPN. So if that is the case it will have applied. Where did you disable h/w acceleration? I can't see the pictures as they haven't been moderated yet. If the VPN is enabled then great and then it is really up to you whether the speed through VPN outways your need for QoS - depends what you will be doing on the network really/how many other devices are being used.
Netduma-Fraser
May 02, 2020NetDuma Partner
Unfortunately you will receive lower speeds when using the VPN through the router, that's why I would suggest you use the feature to only apply to specific services/applications you want to be protected so the rest of the device can use your normal connection unrestricted.
- WacoJohnMay 02, 2020Luminary
Yes, Sir. I would expect lower speeds but not by that much.
Purevpn has an article on the subject with suggestions but some involve modem settings. It's not my modem, belongs to ISP and I am very hesitant to go in there even if I specifically knew how. Furthermore I can't seem to now find that specific article.
I do find How to Turbo Charge Your VPN Speed?
I could disable PVN in the ROUTER and use the Windows app and twiddle around with that.
Thought I would seek your comments before I make things worse. Thank you for your time.
- Netduma-FraserMay 02, 2020NetDuma PartnerJudging by the options from that article there is nothing you can do on that front unfortunately. If you wanted faster speeds then using the Windows app would allow you to do that. If what you want to VPN is dependent on high bandwidth use the app, if it isn't then use Hybrid VPN, that would be my advice.
Not too sure what is going on now. PVN recommended turn off hardware acceleration and firewall and test. Found nothing about firewall in Duma, but shut down QOS entirely (not recommended) and h/w acceleration. Not sure about VPN Traffic section ... All devices set 'do not vpn these services'. At this point, not sure what to 'not vpn'.
I am getting 180 down now. Makes me wonder if PVN is even active. I guess it is as it is enabled. This leaves the question .... leave it as is or turn QOS etc back on? Sorry ... that I am so ignorant.
Notice connected and connectING. (dunno if it is wise to publish IP addresses, but ..)
- Netduma-FraserMay 02, 2020NetDuma PartnerDo Not VPN these services with no services added means the entire device is behind the VPN. So if that is the case it will have applied. Where did you disable h/w acceleration? I can't see the pictures as they haven't been moderated yet. If the VPN is enabled then great and then it is really up to you whether the speed through VPN outways your need for QoS - depends what you will be doing on the network really/how many other devices are being used.
