WacoJohn
May 02, 2020Luminary
Purevpn on XR500 works but throughput slowed.
VPN enabled ... 15mbs down. Disabled .... 200mbs down. Any suggestions? Thank you in advance. firmware 2.3.2.56
- May 02, 2020Do Not VPN these services with no services added means the entire device is behind the VPN. So if that is the case it will have applied. Where did you disable h/w acceleration? I can't see the pictures as they haven't been moderated yet. If the VPN is enabled then great and then it is really up to you whether the speed through VPN outways your need for QoS - depends what you will be doing on the network really/how many other devices are being used.
WacoJohn
Not too sure what is going on now. PVN recommended turn off hardware acceleration and firewall and test. Found nothing about firewall in Duma, but shut down QOS entirely (not recommended) and h/w acceleration. Not sure about VPN Traffic section ... All devices set 'do not vpn these services'. At this point, not sure what to 'not vpn'.
I am getting 180 down now. Makes me wonder if PVN is even active. I guess it is as it is enabled. This leaves the question .... leave it as is or turn QOS etc back on? Sorry ... that I am so ignorant.
Notice connected and connectING. (dunno if it is wise to publish IP addresses, but ..)
Netduma-Fraser
May 02, 2020NetDuma Partner
- WacoJohnMay 02, 2020Luminary
I did not disable h/w acceleration. Confusion on my part. I am getting a very satisfactory throughput. I guess the 15Mb was some kind of fluke. I want to thank you for your help and education. When I grow up, I want to be just like you. :robotwink:
