droesw
Aug 30, 2019Guide
Putting router behind tv affect signal?
 I'm moving to a new place, and was going to keep the router in my room, and the most logical space to keep the router to me would be directly behind my 32" flatscreen tv. This probably makes no diffe...
Aug 30, 2019Guru - Experienced User
You need at least 3 feet in between electronic devices. 6 is preferred.
FURRYe38It is recommended to prevent interference.
I've had AP's mounted to tv's (only location and they didn't want anything exposed) that worked fine. I've also had them work poorly and had to relocate them despite wanting them mounted there. All you can do is try it out and see if it works. If it doesn't, move it.
