droesw
Aug 30, 2019Guide
Putting router behind tv affect signal?
 I'm moving to a new place, and was going to keep the router in my room, and the most logical space to keep the router to me would be directly behind my 32" flatscreen tv. This probably makes no diffe...
droesw
Aug 30, 2019Guide
I'm not really sure on the metal in the tv, I don't even know the model number anymore. My main concern seems obvious but would it even possibly block the wifi signal for the back side of the tv. My tv is against the back of the wall which is facing towards the center of the house, so the tv wouldn't actually be in between the router signal for the majority of the house, basically just my room, so I'm assuming my room would be the only one being affected by the tv. Do you think this would be a safe assumption?
Aug 30, 2019Guru - Experienced User
Tvs can interfer with wifi signals if in close range.
Whats recommended is the wifi router be place out in the open or maybe on a top shelf, non metalic shelving. And away from other electronics if possible There is some play room for distance. You would be best served by testing the placement of the router and checking wifi speeds and internet access and take notice of any bad performance or operation.
The main thing is that you don't want to inhibit wifi signal propagation and coverage it at all possible.
droesw wrote:I'm not really sure on the metal in the tv, I don't even know the model number anymore. My main concern seems obvious but would it even possibly block the wifi signal for the back side of the tv. My tv is against the back of the wall which is facing towards the center of the house, so the tv wouldn't actually be in between the router signal for the majority of the house, basically just my room, so I'm assuming my room would be the only one being affected by the tv. Do you think this would be a safe assumption?
