PapaLung
Sep 28, 2022Apprentice
QOS and connection benchmark
How do I get rid of the gigantic upload spike?
- Sep 28, 2022
If thats happening across two different modems then this may not be something that can be adjusted. Possible the ping testing is loading up and finding it higher as the test begins and as the test continues it lowers and levels off. your getting A+ so that's nothing to worry about.
michaelkenward
Sep 28, 2022Guru - Experienced User
You could start by explaining what you are doing, and, more important, what Netgear device(s) you own.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
