Macky263's avatar
Apr 09, 2019
QOS broken
I have set up the router fully.
The network monitor shows one computer to be using all the bandwidth. This computer is either streaming or browsing, it is never gaming or using Skype/Facetime.
I have bought this router so as to play games whilst this computer streams and browses, it has had 0 effect, here is what I have tried:
> Under QOS, I have put the browsing computer down to as much as 1% allocated bandwidth. It's usage in Network monitor is  identical to before.
> Under QOS, I have used Anti-Bufferbloat at multiple levels between 5 and 95 %. The browsing computer remains at the exact same network usage.
> Under Device manager, I tried blocking the browsing computer, and it did stop, however this is of course unsustainable.
Is this not supposed to be the whole USP of the router? My gaming traffic can go first? What have I done wrong?
  • Hi there - how much bandwidth is this device reguarly using? And what are your total bandwidth speeds
    On Bandwidth Allocation, if you want to apply strict rules, you have to disable Share Excess, but I would not recommend this as it limits the connection speed on all devices on your network.
    What mode is Anti-Bufferbloat set to? If you want it to reduce the bandwidth immediately, you should use Always mode.
    Finally, if the computer is regularly torrenting, make sure you find the option in the Torrent to toggle it to use TCP instead.
    Here's our QoS optimal settings guide: http://support.netduma.com/en/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
    • Macky263's avatar
      Macky263
      Tutor
      My device uses very little bandwidth whilst gaming. Almost every other device in the house downloads, and so uses the full bandwidth.
      The total bandwidth of the internet is between 2.5 and 4.5 mbps.
      Always mode has changed nothing, as I have had it on a while now to no effect.
      I do not torrent.
      It is crucial that I can somehow solve this because the other devices always have downloads running in the backgrounds which activate upon connecting to the router, which their users are unaware of. When I am playing it uses maybe 0.2mbps or so, so I see no reason why that is not being prioritised. I have also tried traffic prioritisation to no effect, using the ports for Rainbow Six Siege as listed elsewhere in the forums.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What is your exact physical setup? Are ALL devices connected to the router? Are you using VLAN, PPPoE or IPv6?
  • FURRYe38's avatar
    Mines set for When High Priority Traffic Is Detected. Been good here.
    System Uptime 06:23:47:47
