Macky263
Apr 09, 2019Tutor
QOS broken
I have set up the router fully.
The network monitor shows one computer to be using all the bandwidth. This computer is either streaming or browsing, it is never gaming or using Skype/Facetime. ...
Netduma_Alex
Aug 06, 2019NetDuma Partner
But they're all connected to the XR500 and not to the upstream router/modem?
And on the Network Setup page, how are you connected? Did you have to enter a login to get the router working?
And on the IPv6 page, is it set to Disabled or not?
Macky263
Aug 06, 2019Tutor
I believe they are connected to the xr500, as the only wifi channels available are the 2.4 and 5 ghz channels labelled NETGEAR85 and NETGEAR85-5 or something.
I did some kind of login for the modem and router, though I can't remember specifics.
Ipv6 reads: Internet connection type - disabled.
- Netduma-FraserAug 06, 2019NetDuma PartnerIn regards to PPPoE if you look in Internet Setup does it require a login? Have you added any manual entries to Traffic Prioritization?
- Macky263Aug 06, 2019Tutor
I am assuming you mean this:
Settings > Setup > Internet setup > Does your internet require a login? - No.
I see nothing about 'PPPoE'.
I manually entered the Siege ports.
- Netduma-FraserAug 06, 2019NetDuma PartnerIs DumaOS Classified Games still enabled? When the PC that uses a lot of bandwidth is streaming are prioritized download packets on Traffic Prioritization information updating rapidly?
