PapaLung
Jun 13, 2022Apprentice
QOS device not found
So I understand that if you reset your xr1000 and then clear offline devices in the device manager, and one of the devices you cleared happened to have its own prioritized setting, it will trip the "Q...
- Jun 14, 2022
Yes, then check in Device Manager that it has the same name and the same device type.
Netduma-Fraser
Jun 13, 2022NetDuma Partner
Only other way is to reconnect the device to the router via the same method as before (WiFi or ethernet), give it the same name and device type and it should work fine then
- PapaLungJun 13, 2022ApprenticeI'll try it. I've erased it's reserved ip, hard reset it and rebooted the router, the only thing I haven't done is physically unhooked the ethernet cable and plug it back in. I'm assuming that is what you mean?
- Netduma-LiamJun 14, 2022NetDuma Partner
