usermac
Jan 02, 2019Luminary
QOS Discord high priority traffic
Has Discord been added to the DUMAOS Classified Games list because now when I lauch Discord app the HIGH PRIORTY TRAFFIC DETTECTED light is on. What happerens if I want to play battlefiled V and use...
Netduma_Jack
Jan 02, 2019NetDuma Partner
Hi Mac - it hasn't been added, no. Are you using Discord on your PC? Or have you added any manual rules to Traffic Prioritization?
usermac
I am useing Discord on a PC and no manual rules have been added Traffic Prioritization. As soon as I launch Discord it triggors Traffic Prioritization light.
- usermacJan 02, 2019Luminary
My device is a computer but for some reason I have it set as a console/xbox. If I change it back to computer then the discord and the priorty light disapears. Only problem is when I have my pc set as device computer dumaos does not deteact any traffic at all. And the geo filter does not do its thing either.
- Netduma-FraserJan 02, 2019NetDuma PartnerSet to a computer then on Traffic Prioritization use the Games Console service. If Discord's ports are within that range it may prioritize them but as it won't be a high bandwidth application it won't cause issues and would prioritize both game and console. You could then try using the Battlefield or Call of Duty service on the Geo-Filter for your game or stick with the device as a console and allow it to prioritize discord and your game at once.
Only way I can get it to work is to not have the PC to be seen by the DUMAOS as an xbox or console. Games now seems to be detected so far.
