usermac
Jan 02, 2019Luminary
QOS Discord high priority traffic
Has Discord been added to the DUMAOS Classified Games list because now when I lauch Discord app the HIGH PRIORTY TRAFFIC DETTECTED light is on. What happerens if I want to play battlefiled V and use...
usermac
Jan 17, 2019Luminary
When it was working with my pc set as computer in the device manager it was detecting almost all games I play and it was not bufferbloating discord either it was only when I had to set my pc as a console because for what ever reason PC mode is not working at the moment.
One other thing that has changed for me is that in the Geo-Filter I have to add my computer and choose a profile and choose one of the games that are set up in the profiles. Before I could just add my pc and was able to choose from filtering or spectating mode.
We need a gameing PC MODE with netduma consoles seeem to be getting priority
BuuBot
Jan 17, 2019Aspirant
Discord for me sounds raspy and nasty aswell. Can you add some form of blanket 'whitelist' rule to Geo-Filter so Discord can work again? Or I guess techincally it would be fixed if I could use the PC settings of dumaos instead of console.
- Netduma-FraserJan 17, 2019NetDuma PartnerBuuBot, that means your whole device will be VPN'd so it still works.
usermac, if it was a PC you will have always had to select a service on the Geo-Filter, only if its a console you don't have to choose. It's a good suggestion, we'll likely implement it.
BuuBot, is Discord being blocked by the Geo-Filter? In that case you can just allow it yourself through the ping panel - usermacFeb 08, 2019Luminary
New problems with this High Priority traffic,
Now the high priority traffic gets stuck even if I close all applications the things still stays on. The only way to turn this off is to do a factory reset. I can no longer use my PC in console mode because the traffic priority will get stuck even if I switch the PC off it still limits the bandwidth.
Second issue the Duma games does not detect online game's for me if I am using in PC mode the games tested while connected to online servers in game
Battlefield
Call of duty black ops 4
Player Unknown Battlegrounds
Apex Legends
These are some of the most popular games out on PC This makes me question what is the DUMA OS CLASSIFIED GAMES actually doing for us PC gamers. So far it is doing nothing unless you set you PC up to look like its a console.Not sure what else to do other than not bother useing the thing untill something gets fixed :(
Actually I am going to take PUBG off the list of games this is working and this is with the Device seen as a PC.
Black OPS 4 does not work but strangely the Blizzard app triggers the priority and then switches off when in game and that includes being online.
I also have a idea could some of the DumaOS Classified Games be Dissocialised to give us a clue on what PC game are compatible.
Netduma says it covers all console game and most PC GAMES but only one game works for me so far and thats PUBG.:smileylol:
- Netduma-FraserFeb 09, 2019NetDuma PartnerThe Traffic Prioritization light can take a little bit of time to disable properly, usually no longer than 30s-1min, how long were you waiting and was high priority packets updating while it was still on?
For PC games we use Deep Packet Inspection, this is different from how we detect consoles. So any PC game updates can cause it to become outdated so thank you for bringing our attention to it and I'll pass it on to our team to retest. In terms of Apex Legends as it's very new we're still working on compatibility with the game.
