usermac
Jan 02, 2019Luminary
QOS Discord high priority traffic
Has Discord been added to the DUMAOS Classified Games list because now when I lauch Discord app the HIGH PRIORTY TRAFFIC DETTECTED light is on. What happerens if I want to play battlefiled V and use...
BuuBot
Jan 17, 2019Aspirant
Discord for me sounds raspy and nasty aswell. Can you add some form of blanket 'whitelist' rule to Geo-Filter so Discord can work again? Or I guess techincally it would be fixed if I could use the PC settings of dumaos instead of console.
Netduma-Fraser
Jan 17, 2019NetDuma Partner
BuuBot, that means your whole device will be VPN'd so it still works.
usermac, if it was a PC you will have always had to select a service on the Geo-Filter, only if its a console you don't have to choose. It's a good suggestion, we'll likely implement it.
BuuBot, is Discord being blocked by the Geo-Filter? In that case you can just allow it yourself through the ping panel
