droesw
Nov 12, 2019Guide
QoS not working properly because of docsis 3.1?
I am currently on my third XR500 in the past year. The first one I have I returned it because of a issue that I wasn't originally informed was just a firmware issue, but everything else worked great ...
Netduma-Fraser
Nov 12, 2019NetDuma Partner
I think the easiest way for us to see what is happening is to provide a screenshot. Could you open the Anti-Bufferbloat option menu and take a screenshot of the entire page please with the normal settings you're using.
- droeswNov 14, 2019Guide
These are the settings I have them on currently, and yes I have share excess enabled. I've tried giving a very large percent of bandwidth to a certain device before testing it, and also have tested it by only having 1 device connected before testing, but it still makes no difference. No matter how my settings are, if I have QoS enabled I always get a download speed about 40-50mbps lower than what I have it set to, but when I have OoS disabled it gives me my normal maximun speed that I should get from my ISP. I've also tried swithching it to "always" have anti--bufferbloat on instead of "when high priority traffic detected", but that hasn't made any difference either. I've tried doing factory resets multiple times but it's never fixed it whatsoever.
Another picture of my QoS settings to go along with my last post
