Cindas
Nov 13, 2022Tutor
Qos not working still have bufferbloat
have the xr1000 router, dhcp connection Using to play call of duty but the connection is really bad. In public the matches its fine but i play privete matches, competitive mode in cod and it seems a...
Nov 13, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you wired or wireless connected to the router? Wired is preferred.
Be sure to close all background apps before running any bufferbloat testing.
Try a different PC to compare results.
How is QoS configured on the router?
Cindas
Nov 13, 2022Tutor
I have the xr1000 router, dhcp connection
Using tô play call of duty but the connection is really bad
In public the matches its fine but i play privete matches, competitive mode in cod and seems a diferente game,same ping, but thd movment is slower, seems like i have delay to shot, to aim
Bad hit dettetcion
Need help
I already changed the qos percentage but nothing happened
Disable traffic priorization and still the same
Run a test o wave bufferoat.com (i think that is the site) and i got an A "YOUR CONNECTION HAS A SLIGHTLY UNDER LOAD"
PLEASE,DOES ANYBODY SUFFERING WITH THAT?
Bad hit dettetcion
Need help
- KitsapNov 13, 2022Master
Bad hit dettetcion
Need help
PLEASE,DOES ANYBODY SUFFERING WITH THAT?You would get more and better answers if you posted your question in the section Netgear has dedicated to Nighthawk Pro Gaming Routers.
Dynamic QoS is of dubious value when using a modern broadband internet connection. You will get better performance out of your Netgear router if you disable Dynamic QoS, traffic meter, and access control in your configuration. Each of these "features" disable hardware that supports performance.
