Cindas
Nov 13, 2022Tutor
Qos not working still have bufferbloat
have the xr1000 router, dhcp connection Using to play call of duty but the connection is really bad. In public the matches its fine but i play privete matches, competitive mode in cod and it seems a...
Cindas
Nov 13, 2022Tutor
hey furry
1)firmware:1.0.0.64
2) I AM FROM BRAZIL, use dhcp connection, dmz desable, upnp desable
3) i am using a good quality lan cable between modem and router, actually i am using the cable thas comes with the produtct (xr1000)
4) Using wired connection
5) all backgrounds are closed when i am running the test or playing
6) qos i set 30% ,10%,70%
auto set up
used geo filter , denyied some servers (peer servers)
but unfornately, unplayable private matches
no matter who creates the host or how many people are in the looby once i start playing the delay comes
Nov 14, 2022Guru - Experienced User
