iKills
Sep 08, 2022Follower
QoS on XR500
I just got 1gbps fiber optic internet today. I have my PC hardwired to my XR500 router. My upload and download speeds are both around 930mbps. Other than my PC there's 1 laptop, 3 phones, and 2 ...
Netduma-Liam
Sep 09, 2022NetDuma Partner
What firmware version are you currently running on the XR?
You don't need to allocate that much bandwidth to the gaming PC, gaming doesn't use much bandwidth at all.
What I would suggest you do is set the Congestion Control sliders to about 60% each, then leave it set to Auto-enable.
This way, when you start playing something, all devices on the network will be throttled slightly and your gaming traffic will be prioritised. Other devices will still be able to use the internet and it should all feel normal still.
