Paras123
Jul 09, 2019Aspirant
Qos Priority not saving
Ive been having a issuse for the past week or so with my Qos not saving after i click apply what happens is that i click i the device i want to mange my priority level for and choose "low" "medium" "...
Jul 09, 2019Guru - Experienced User
Try a different browser.
Please post about this in the Nighthawk router forum for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
- Paras123Jul 09, 2019Aspirant
i have the r8500 and i have used a differnet browsers and it still does not work any other ideas ?
- Netduma_AlexJul 10, 2019NetDuma Partner
Sorry but this forum is for Nighthawk PRO Gaming Routers, specifically the XR300, XR450, XR500 and XR700.
You need to post in the correct forum for your model: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thanks!
