Martdog23
Jun 16, 2020Guide
QOS settings for 1 gig down/40 meg up, Xfinity cable modem
Hi, I’ve been a competitive video gamer for a long time and have just recently decided to buy my own equipment rather than use the ISPs equipment (shocker I know). I love the NETGEAR nighthawk gaming ...
Martdog23
Jun 24, 2020Guide
So just a little update on my experience. I have gone back to no ipv6 enabled. I lowered my overall WiFi speed to 800 mbps rather than at the recommended 945 mbps. Yes still have QoS on and at 70%sliders. I also have ports forwarded 3478-3480 for the PS4 along with an address reservation. This seems to be working well at the moment.
Netduma-Fraser
Jun 24, 2020NetDuma Partner
Great to hear that, thank you for the update. Do keep us posted on how you get on.
- Martdog23Jul 05, 2020GuideCan you explain to me what “respond to ping on internet port” does? And possibly why it is beneficial to having it on and how it relates to gaming? Thanks for all the advice by the way. Always good to bounce ideas off people.
- Netduma-FraserJul 06, 2020NetDuma PartnerNot much I can say for what it does, if someone pings your IP address then the router will send a response. I'd normally suggest leaving it on (unless you're very security concious) as I could envisage it might affect the accuracy of the Geo-Filter ping.
