GhillieK9
Oct 19, 2019Apprentice
QoS Traffic Prioritization Selector for IP Cameras?
Hello, I have the XR700 and I wanted to add some devices in the traffic prioritization under QoS. When I click the device (for example and IP camera), the second page has some options under the "...
Netduma-Fraser
Oct 20, 2019NetDuma Partner
Hello, firstly are their live streaming IP cameras? Do you know how much bandwidth they will use? Traffic Prioritization is a feature meant for low bandwidth applications like games. If you prioritize something that uses a lot of bandwidth this can have adverse affects on your network.
There isn't a basic setting at the moment but if you look on the manufacturers website for your model they will most likely have information on what ports are used.
- GhillieK9Oct 20, 2019ApprenticeHi! They're those Yi cameras...the black 1080p one. So I have an app on my phone and can pull it up and watch live. We have a few in the house but they're not pulled up all the time. One is for the baby so that one can be quite often. They have an SD or HD option available. I'll have to double check yi website or maybe even send them an email but I haven't seen anything before on their website.
I had no idea that prioritizing them could be bad. Do you know why that is? I mostly did it because sometimes it seems like it's taking a while to pull them up. But I can remove them...- Netduma-FraserOct 20, 2019NetDuma PartnerTraffic Prioritization supercedes QoS so if you're having a lot of bandwidth going through the feature then that can cause all your other devices to lag. If you use Anti-Bufferbloat at around 70% for download & upload at Always then that should resolve your issue if it's not an inherent issue with the app/camera.
- GhillieK9Oct 20, 2019ApprenticeThank you! I'll delete those and just keep the stock gaming one on that's on by default. Thanks!
