Opularity's avatar
Sep 27, 2020
QOS Work with Extenders
Hi Everyone, Im Wondering if QOS works with/through extenders. I have the xr500 router downstairs and my bedroom with my gaming setup is upstairs and i connect my PC and PS4 to the Ex7700 extender...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Sep 28, 2020
    Yes that is right. An access point does not hand out IPs to devices so the device gets the IP direct from the router, hence it will then be configurable on the router. No need to apologize, totally understand!
