Luke140898
Jun 22, 2020Guide
Qos
Everytime i adjust my qos settings it says "RPC error 'ERROR_NOENT': Rule not found in chain" Thnaks luke
Netduma-Fraser
Jun 23, 2020NetDuma Partner
Could you perform a factory reset please and see if you get the issue after that?
- Luke140898Jun 23, 2020Guide
hi , thanks it fixed the problem with qos . i have a problem with my ping mainly on call of duty moderrn warfare that i have noticed would i have to make a new post ?
- Netduma-FraserJun 23, 2020NetDuma PartnerNo need, what is the issue you're having specifically?
ive noticed i get ping spikes occasionally between 19ms -30 ms on duma os but on modern warfare it shows i have a ping of 30, 40 or 50 ms sometimes i have Qos enabled and hyper traffic enabled i was wondering if this is a problem with my setup ? i do use the geo filter but i cant get a game under that ping in game it always shows that ive got atleast 33ms ping.
