batunkhal
Mar 09, 2022Follower
Question about Nighthawk xr500
I bought my router a week ago and found out that once every 24 hours, it will lose connection for like 30 seconds and then come back up. I'm just wondering if there is a way to fix this? Is it some...
Mar 10, 2022Guru - Experienced User
Be sure and change the default DHCP IP address pool side to 192.168.1.100 to .200.
