batunkhal
Mar 09, 2022Follower
Question about Nighthawk xr500
I bought my router a week ago and found out that once every 24 hours, it will lose connection for like 30 seconds and then come back up. I'm just wondering if there is a way to fix this? Is it some...
Netduma-Liam
Mar 10, 2022NetDuma Partner
Could you please confirm which firmware version you're runnning as mentioned above?
Are all devices loses connection, both wired and wireless?
Do you have to go anything to bring the connection back up or does it restore itself?
