Somatics
Nov 04, 2020Tutor
Question about QoS and WiFi access points on xr500
Hi, just got my XR500 the other day and I'm loving it but haven't found my optimized settings yet as I haven't had much time to get into it. Setup is an Arris Surfboard SB 8200 Modem with the XR500...
- Nov 04, 2020There should be no performance decrease by using that in AP mode so you can do that if needed. That is the recommended starting point yes, you can eliminate spikes by experimenting with the Anti-Bufferbloat percentage. I would recommend having a look at our optimal settings guides here: http://support.netduma.com/en/support/solutions/folders/16000090646
Netduma-Fraser
Nov 04, 2020NetDuma Partner
