Marv-K
Feb 21, 2023Guide
Question About Strict Mode ( Geofilter )
I have a question about strict mode (Warzone 2), if I activated strict mode, and then also activate geofilter (georgia us), selected (I'm in Europe), then start the game, and log in and when i'm in th...
Netduma-Liam
Feb 21, 2023NetDuma Partner
Disabling strict mode will mean that Geo-filter will ONLY filter peer connections, not servers. This isn't particularly useful for Warzone, because it uses server-based matchmaking, so disabling Strict Mode is essentially like disabling filtering mode.
A small point to clarify on, Geo-filter doesn't actively connect you to the best servers, it only blocks servers. When you set your radius/polygon, you are essentially telling Geo-filter to block anything outside of these areas.
When you struggle to play cross-play, are you seeing any 'blocked server' icons on the map? You may need to manually allow these in order to play cross play. To do this, click on the server icon and click 'Allow' on the panel that appears below the map.
