pinkpig1983
May 06, 2020Aspirant
question about the counterpart's location of the xr500 geo filter.
Hi there I am a Korean who enjoys pes2020 as a PlayStation4. I'm playing pes2020 with my korean friends, but the geofilter's location is marked as US. Most are marked in the United States...
pinkpig1983
As in the attached picture, two markers are displayed in both the United States and Korea.
Ping to that icon in the US is 50~60ms and Korea is 5~10ms.
Netduma-Fraser
May 06, 2020NetDuma Partner
Okay so definitely mislocated there, that is something we can easily resolve - it may actually be a server that is needed for online play and so wouldn't affect your connection with the 5-10ms server being the host. If you disable Ping Assist completely can you still get games and if so are they of better quality?
- pinkpig1983May 06, 2020Aspirant
The game is played even if Ping Assist is disabled.
However, the quality is not affected. same
- Netduma-FraserMay 07, 2020NetDuma PartnerJust to clarify, does the US server still get through with Ping Assist disabled? The ping is fine so it shouldn't be causing you any issues. When did the issues first start?
