Bansisingh
Nov 13, 2018Tutor
Question regarding XR700
Does it support OpenVPN Client? For example if I were to manually configure it with my own VPN Server, instead of using HMA.
- Netduma_JackNetDuma Partner
You're referring to a VPN client rather than a server right? If so, you can use our Hybrid VPN solution for this. You should be able to apply your provider's OpenVN config file in the advanced section.
This guide explains how - it's written for our Netduma R1 but the settings should all be the same: http://support.netduma.com/en/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn-step-5-
