Fenderman1
Jun 29, 2018Follower
Question with wifi speed
Hello, I just purchased and installed my nighthawk xr500 router and my max wifi speed that I'm able to push is 120megs to my devices through my wifi (phone, fire stick ect). I have a fiber internet se...
Killhippie
Jul 03, 2018Prodigy
Have you got any wired connections? Also do you have antibufferbloat set to 70%? If you do you will have reduced bandwidth, you can select when 'high priority traffic is detected' so then when not gaming you should get a full pipe rather than the constrained one to eliminate lag. Be aware that 70% is a guide, if you don't have a busy house and never saturate your network you could set it to 97% quite happily or even 99% it depends on your home environment, the amount of devices using intensive bandwdth and of course how many people are in your home too. Follwing Jacks advice is also very useful in case it is wifi related and not settings.
