jmock
May 20, 2018Tutor
Questions about geo-filter
I’m strongly considering buying the XR500 to replace my R7000 but was wondering if it’s possible to only set the geo-filter per-port or for wired devices only? My Xbox and PS4 are wired and all oth...
- May 20, 2018For the Geo-Filter you pick the devices you want it to apply to so you would just select your Xbox & PS4. All other devices would be unaffected by the Geo-Filter.
Netduma-Fraser
May 20, 2018NetDuma Partner
- jmockMay 20, 2018TutorAwesome, thanks for the super-quick response!
