Andrewmike's avatar
Andrewmike
Follower
May 22, 2019
Questions about geo-filter
I currently have the NetGear Nighthawk AX12 router with the 6XS(EX8000) booster. I have heard about Geo-Filter and was want to know if there is Geo-Filter or something similar to it on this particular Router? If this exists on this particular router how can I set it up?
  • Hi Andrew, the Geo-Filter is an exclusive feature for the DumaOS software and is only available on Nighthawk Pro Gaming routers or from Netduma ourselves.
1 Reply
