Ghost865
Jun 02, 2019Aspirant
questions about settings
ok first things first why is my ping/connection in the RED wile useing this XR500 on PS4 PRO (wired) I play alot of BF4 as long as i useing this router my connection & speeds are garbage.Every game i...
Netduma-Fraser
Jun 02, 2019NetDuma Partner
Well QoS is literally designed to prevent lag so definitely recommend you enable that. Use 'When High Priority Traffic Detected' with 70% for download & upload on Anti-Bufferbloat. Leave DumaOS Classified Games enabled on Traffic Prioritization, remove any manual rules if youve added any. Don't use the Geo-Filter for this game and are you selecting the closest server? Are you connecting to WiFi or ethernet? An update shouldn't have 'fried' the router at all, unless power was unplugged during perhaps. A factory reset should resolve that though.
Ghost865
Im not shure on how to connect to the closest server im still new to this router, the server i allways play on is in north america. I hve both set to 70%. My ps4 is wired and i hve my ps4 set to highest prority over all other devises. Im affraid to do a factory reset cause it took me 4ever just to get it connected to the internet lol!! As far as the update i (tryed) to update the other router last night b4 i had to go bck to best buy and exchange it cause updateddid sumthing to the router it never updated i waited for way over a hour for it to update but never did & the update did sumthing to hardware i hve no clue how this happened
- Netduma-FraserJun 02, 2019NetDuma PartnerThat's with the Geo-Filter but for BF4 they should have a server browser that you can use so you can connect to one that has the best connection. Okay well you've got another working router so after changing QoS is it any better? Where are you located?
- Ghost865Jun 02, 2019AspirantSo i guess theres no need in useing geo filter for bf4? Im located in Knoxville, Tennessee. Ive also noticed that my hit detection is not so good with the xr500 but when i used just my comcast modem/router my hit det. Was fine.. Yes the XR500 works but its not performing like i was hoping it would when i purchsed it lol.. Also i still cant figure out why my connection in bf4 is red bar"d like in the pic i posted
