bloodbucket
Sep 20, 2019Aspirant
questions about XR500
so i want to buy the XR500 pro gaming and i have a few questions like will this router work in my country (iran) and also do i have to pay a monthly bill or something? i dont have a master card or pa...
Netduma_Alex
Sep 20, 2019NetDuma Partner
The XR500 works with your existing broadband connection. There's no reccuring fee once you've bought the product, just whatever your current broadband provider is charging.
bloodbucket
so i just have to buy it and plug it in and it will work.
- FURRYe38Sep 20, 2019Guru - Experienced User
Be aware of Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.- Netduma-FraserSep 21, 2019NetDuma PartnerIt should work with all internet providers so yes should be no reason you can't plug and play. Keep in mind you'll need to continue to pay your Internet Provider for Internet monthly but the router is a one time cost.
